1 Ton cherry picker?
NETX_S4
Bronco 2
Will the 1-ton Cherry Picker from Harbor Freight provide enough capacity and clearance to get a B2 engine out of the bay, or do you need the 2-ton?
tw205
Bronson michigan
1ton is 2000lbs. The lift capacity is more than sufficient. As long as you don’t use 3 foot of chain from the engine to the lift you should be fine.
