N NETX_S4 New member Joined Feb 13, 2023 Messages 12 Reaction score 3 Points 3 Vehicle Year 1988 Vehicle Bronco 2 Mar 16, 2023 #1 Will the 1-ton Cherry Picker from Harbor Freight provide enough capacity and clearance to get a B2 engine out of the bay, or do you need the 2-ton?
tw205 Active member U.S. Military - Veteran Joined Jan 23, 2011 Messages 332 Reaction score 124 Points 43 Location Bronson michigan Vehicle Year 1985 Vehicle Ford Suspension Style 4wd Mar 17, 2023 #2 1ton is 2000lbs. The lift capacity is more than sufficient. As long as you don’t use 3 foot of chain from the engine to the lift you should be fine.
