2.8 tear down
TenSeven
Tear down on an 85 2.8 that after being cleaned up initially ran well then started to get hot and blew the radiator up. After radiator fix there is now coolant from both exhausts during cranking over.
Before tear down two tests were done. Compression and the 'Glove Test', you guys are probably already familiar with (where a rubber glove is secured over the radiator fill and the radiator overflow is plugged. Then you check to see if the glove is inflating while cranking over the engine. Each plugged can be pulled to see which cylinder is leaking into the cooling system.)
Cylinder
#1- 125lbs
#2- 98lbs, positive Glove Test
#3- 120lbs
#4- 60lbs, positive Glove Test
#5- 95lbs, positive Glove Test
#6- 120lbs
http://s1362.photobucket.com/user/EighteensTen7/library/Head Gasket
Looks as though there's been a breech of the head gasket between cylinders 1&2 and 4&5.
Question, are the markings on the Pistons factory stock or are they aftermarket?
Thanks
ab_slack
New Joisey
2.9L
I don't know about the piston marking. The concern that immediately comes to mind after such an overheat is what conditions the heads are since they are known to crack.
TenSeven
Thanks. I've heard these heads are prone to cracking (2.9's even more so). Visually there are no obvious cracks but I'll need to have them Magnufluxed to be sure.
Shame seeing it leaking coolant out the exhaust's after having run so well.
ab_slack
New Joisey
2.9L
I agree, very sad to see. If you dont' get an answer here try TRS as that is more active and most BII issues are true for Rangers as well.
It was unclear to me if this happened after doing a rebuild and so you had to tear down again or if this just happened after getting it running after a long time. I guess it probably was the latter.
TenSeven
Ya, the latter, first time getting it running after buying it and changing a few gaskets. I'll get the heads cleaned up and checked.
Thanks
