Bruce33905
- Oct 19, 2018
- 8
- Fort Myers, Florida
- 1988
- 2.9
I got a 88 b2. It turns over but won’T start. I get codes o89, 10, c14, c18. Everything on the ignition has been changed. The fuel pressure is at 42psi. Could someone give me some advice please. Thank you
***update***
Ok! So I got it running but will only run without spout at a idle. Will not start with spout in. Starts with spout out, idles 600 rpm and if you touch throttle it dies. Any advice, tips or test I can do? Any information will be appreciated
***update again***
Ok so I would turn the key off and back and kept getting random codes. Most codes was associated with ignition. Wiring was a mess so I got it all out sorted through it. Also pulled cover off computer and found a couple burnt spots on the circuit board. Got a new computer and put it back together... she is running like a top
***update***
***update again***
