I have posted to this thread earlier because i am having probably the same issue as Mhollis1. I also am still searching for the fix. As a recap what a mechanic replaced for me: Distributor, wires, plugs, condensor, 2 TPS's, MAP sensor, o2 sensor, temp intake sensor, coolant temp sensor, battery, battery cables, alternator, 3 ICM's, 9 ECM's, 2 HP pumps, 5 lift pumps, ignition switch, electric connectors at inertia switch & both fuel pumps, fuel filter, relays and their connectors. I still have the problem, i can idle it in the driveway for 20-30 minutes and we can watch the fuel pressure gauge drop from about 40 to <10 when it runs bad and conchs out won't restart until 10-20 minutes. Usually when i get stuck i'm not far from home and restart it and just get it home in less than 20 minutes. I don't get any codes really on the odb1. Last week i did the short pin test to turn on both fuel pumps, thing is i can not hear the tank pump, can not feel any vibrations with my hand on the tank, can not hear anything when i put a funnel in the filler neck and my ear next to it. I can hear the HP pump and it sounds a little whinny. I'm getting someone in a couple of weeks to test my theory -- the wire to rear tank though already checked for V drop at cold maybe is corroded and gets heated causing lower voltage only at that time to lift pump so pump somewhat quickly burns out from low voltage leaving the HP pump to miracously keep it running until HP pump gets heated up shuts down. And somehow the HP pump is now the only one that actually runs. Just a non-mechanic researcher hypothesis. But someone said car won't run without both of them working. Yet one shop says "yea we checked voltage and it is good at the lift pump, but 12 volts straight to the pump and it won't run (that was at the 4th pump)" Not giving up $@#!%^^@#$&
