94_5LitreRanger
- Sep 15, 2012
- 1
- 1994
Hey guys
First off thanks in advance to anyone that can help me troubleshoot this more than i have already so i have a 1986 Bronco II with a 2.9L v6 manual transfer, manual 5 spd, locking warn, 4x4 etc etc...
Anyways long story short i needed a fuel pump so ive so far replaced the in tank fuel pump, it also has that cylinder type of fuel filter the older style unscrewed that which was a BITCH. replaced that and also replaced the inline fuel pump the one on the drivers side frame rail. made all good connections from what i would figure to be proper made sure all fuel lines were snugged up and not leaking and c clips were in properly tried starting it it sits there trying to turn over so my buddies dad said check the shrader valve at the injectors i unscrewed that no hiss nothing coming out so no pressure building up obviously i also couldnt hear the pump which isnt right i know that. when i first installed the fuel pump the one in the tank i heard it turn on once then ever since then it hasnt and when it did the truck ran for like 5 seconds then shut off even with my foot giving it some gas and my buddies dad also mentioned to check the 3 relays on the passenger side one of them being fuel pump relay i believe the green colored one well mine has a bit of corrosion on the one tooth off the relay so i went to pick n pull go another off a bronco II 80's havnt put that in yet but besides all that does anyone has any other suggestions?
id appreciate the help!
