- Dec 2, 2019
- 11
- 1
- Hogne Belgium
- 1988
- Ford Bronco II
- Suspension Style
- 4wd
Hello, I will try to explain my problem to you. I start the engine and I put the lever on R or D of my A4LD gearbox, there I feel a good engagement as if it was normal and then nothing for about 1-2 minutes the Bronco does not want to move, after this time it starts to move forward or backward slowly at the start and after rolling a little bit it drives normally, it has good acceleration, the gears shift well, no slipping. Do you have any idea what is causing this delay? Another question, is it possible to adapt a European manual gearbox from a car that has the same engine?
