Better cross bars for roof
Kawika7725
Ford Bronco ll
I’m trying to look for thicker crossbars to be able to install kayak mounts on my roof but the crossbars I have are too thin and I can’t find any bars that are able to mount onto the rails. Anyone have any suggestions? 1989 bronco ll
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
I've made rails and mounts for the gutter on my ranger. Its not too hard to do if you have a welder.
duffy
I would think you could make the mounts fit to the cross bars with a bit of back yard engineering.
Not many Bronco 2's had the roof rack option I don't think. I've never seen one in person, but I don't think they were much for carrying anything at all. I thought someone had mentioned somewhere like 150 pounds, then again its a short narrow wheelbase vehicle, so adding weight up top isn't a good idea.
Only thing I could think of would be to modify the current cross rails you have with some angle iron or square tubing maybe? Use the current mounting brackets and fabricate new cross rails. I can't think of any vehicles that use the same rack system either so trying to get some extra parts to mess with would be a pain too.
May have to completely re-invent the wheel with a new roof rail system and build your own kayak mounts yourself....just make sure you seal all the holes in the roof really well.
86isuzu
Firefighter
EMT / Paramedic
North Collins, NY
I used a set of universal cross bars from Harbor Freight I think it was...
It worked ok. Looked a little goofy, because I couldn't find anything to work with the factory bars either.
