body mounts
Pelzworld
85 B2 ISO the front two for the frame to the core support & hardware if possible. I don't want to have to buy a whole set-looks like a nightmare to change out. If it's not, please advise. Had to replace core support and cut the old ones out.
bronco2fan
Ft. Hood, TX.
They're not hard at all. And if you're replacing them may as well do them all. If you order them you're gonna need all new hardware. Most kits will come with them. James Duff sells poly ones and the hardware.
I recommend having a Sawzall and helper because believe me they will be rusted together and the original bolts will be toast.
Took me 3 or 4 hours because you have to remove interior pieces to access the holes.
