Bronco II 1987 Project Automatic 2.9 V6
donzoh1
I finally got the transmission out and found the flex plate fractured in three places around the center. The six hole center section had broken completely away from the plate. When I removed the bolts, the 6 hole crankshaft spacer fell out (didn't know that was back there). The small raised rim around the center of the spacer was 80% gone so that it no longer holds the spacer in the center of the flex plate. While the bolts will hold it generally in place, I ordered the new spacer from Sonnax figuring this spacer definitely needs to be centered exactly in the new flex plate.
Any thoughts on whether using the old spacer would work?
