Bronco II doubler build pics
74bronco2
January 2012 OTOTM Winner
Dayton WA.
4.0 Liter
Just finished sealing it up. Cant wait to get it installed!
shaft parts before machining
the welded gap
compleat!
The Jester Race
ΜΟΛΩΝ ΛΑΒ&
Sacramento, Kalifornia
Ford, BMW
Cool, I'v been thinking about building one.
Is the .25" or .375" plate that you used?
-Jester
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
Nice work. Wanna build mine next?
country0001
Stillwater, OK
Ford,Ford
sweet,I wanna do this one day, just need to find the 1354 m. How hard was it?
88_Eddie
Raleigh, NC
same here, i've been cruising c-list everyday for the last 6 months, all i can find are 1354E's
74bronco2
Dayton WA.
4.0 Liter
-Jester
if i was to build another, I would us .50 aluminum it will save headach when machining the splitter shaft, and weight also.
74bronco2
Dayton WA.
4.0 Liter
The junkyards here are full of them. Also keep an eye out for 90s explorer e or m tcases thay have a 6 pinion planetary instead of the 4, and the 1350 are usable i just wanted to eliminate the slip yoke and small internal ujoint.
As for the difficulty, its not for the bolt on mechanic but a little metal working experience, mechanical ability, and the right parts its not too bad.
slammer67
Salida, Colorado
ranger
cool.
is that a two piece shaft? how does that work? did you weld it together or what?
74bronco2
Dayton WA.
4.0 Liter
cool.
I had the two shafts machined and pressed together then welded
slammer67
Salida, Colorado
ranger
ok.
I did alot of research on doubler before I did mine, and I ran across a couple with pressed and welded shafts that broke. that's the reason I went with the dd machine doubler kit because it had a solid shaft.
keep us posted how it works, I'd like to go the diy route next time if it'll hold up.
I'm anxious to see your shifter setup. it looks like the one lever is hitting the seperator plate. you'll need some creative shifter setup.
here's mine
it's a push-pull setup. I have more picks of the bracket if you want to see.
my rear case is electric shift so I dont have the same probs. I do have a 1354m case to put is so Id like to see what you come up with.
good job
59bisquik
April 2011 OTOTM Winner
Barstow, CA
I run a 1350/1350 combo. The rear case uses a modified stock floor shifter to shift it. The front or doubler, just uses a push pull lever. Down for normal, up for low range. When I used to have an electric rear case, I used a stock shifter to shift the doubler and of course the electric shifter for the rear case.
74bronco2
Dayton WA.
4.0 Liter
installed pics
the levers
74bronco2
Dayton WA.
4.0 Liter
installed pics
the levers
disciplerocks
Evansville, IN
Looks good. Wish I had the expirience and tools to build one.
88_Eddie
Raleigh, NC
are you planning on trussing the rear axle? i've heard of them gettin bent with doublers
7111127
Coweta Oklahoma
dumb ? i new 2 this stuff what is the reason for doing this?
disciplerocks
Evansville, IN
You know how you put your transfer case in 4low? Well this makes it 4low on top of 4low. Awesome crawl ratio.
59bisquik
Barstow, CA
For a mud rig, this would be a waste of time, since you normally want some wheel speed. With my doubler engaged and the tranny in overdrive, I can barely hit 15mph! However, if you have a rock rig, control and crawl ratio is where its at. For a rock rig, hands down the best mod!
