Hunamongyou
- Dec 4, 2017
- 2
- 1985
- V-8
My 85 Bronco ii is not terribly peppy even after the duraspark conversion and replacing the variable venturi carb with a mustang ii carb. I've decided to go radical and put in a freshly-rebuilt 302 HO engine I bought and a new process 4-speed with transfer case I removed from an 85 F-150. The biggest wrinkle is that I'm putting the running gear into a 95 explorer chassis that I've narrowed and shortened to Bii length and width. At this point, I have the engine-transmission, transfer case set in the modified chassis and engine is bolted down. Transmission is yet to be mounted on what will be a newly fabricated cross member. When I get all the running gear complete including drive shafts, I will lift the cab of my Bronco ii and copy the mounting locations to the explorer chassis. I will modify the firewall/floorpan as necessary to effect the install. I'm also planning a roll cage install to coincide with dropping the body onto the modified chassis. When I'm done, I plan to have about 300 hp under the hood which should roll me down the road (or trail) with a bit more zip. If anyone else has done this, I'd like to hear from you. If anyone has any questions about what I'm doing, I'll try to answer them. No need to ask why I'm doing it though. I'm doing it because I want to- that's the American way.
