bronco project
4xranger
sunny St. George Utah
1992 ranger wit
[/IMG]
http://
:annoyed:ok so now i have to resize all pics first so i will post later.
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
I think those pics are of when he first got it.It's a good base to start with. Hopefully he also posts some pics of progress over the two years.
Richard
4xranger
1992 ranger wit
lets try this agian, got it home in the garage and started deconstrution of the bronco. first off with the top,and gut the interior so i could pull the body off the frame and do some clean up and paint and decide what i don't need.
after removing the top i cut the brace off above the side window and installed across the top to reinforce the top and give me something to bend a lip down from to mach the sides.
CHKNFKR
Illinois
545 CID
I love that first pic, the placement of the bicycle and the angle, looks like the bii is sporting a bicycle tire
4xranger
1992 ranger wit
i spent a couple of days with a grinder and wire wheel to clean up frame and finished takeing everything off so i had just a bare frame. Once completted i set body back on made my own body lift from 2'' pipe and flat plate
flipped rear leafs around to extend wheelbase. pushed front axle forward so now it sit's at 101'' . picked up a ford 9" and dana 44 from a 1979 ford f-150 for $300.00 not a bad buy but there open diff's with 3:50 geers and full time hubs :badidea:
4xranger
1992 ranger wit
next i ordered coils from rusty's offroad for a xj with a 8.5 lift and fabricated coil buckets to match the hight of rear. and i set rear by flipping the springs around and welding new saddles on after setting the pitch for the rear axle.
4xranger
1992 ranger wit
cut out fenders to clear tires right now i have BF mud terrains 35x12.5x15 plan on running 40x13.5x15.
4xranger
1992 ranger wit
picked up 302 to move the bronco along a little better than the wimpy 2.8 along with a c6 tranny and a np 208 tcase, fabricated motor mounts and tranny mount, then pulled all apart agian to do some paint.
4xranger
1992 ranger wit
got the body back on everything hooked up and running so next i fabricated front and rear bumpers that would take a little abuse on the rocks. i used 1/4''x6'' flat for the top and face and used 3/16'' x 4'' for bottom on both front and rear. push bar is 2''x2''x3/16'' .
4xranger
1992 ranger wit
finished cutting out rear wheel wells and fabricated new ones to fit the opening, pacthed rear of cab where top was cut off and used the hinges from rear hatch to attach to bottom so it works like a truck tailgate and pacthed in corners. installed gas fill behind rear taillight still working on some sort of hinge for light.
4xranger
1992 ranger wit
well the 302 i picked up is a POS tired of messing with it, found a wrecked 1997 mecury mountaineer so i pulled the fuel injected 5.0 ,complete wireing harness and dash. got everything installed and wired and what a differance this made fires right up and runs like a dream :headbang:
4xranger
1992 ranger wit
a couple of pics of the dash from the mountianeer.
4xranger
1992 ranger wit
decided to make fender flares so the bronco don't have to be a trailer queen all the time,i kinda want to drive it down the road once in a while. started on the some body work and sanding for paint, all in primer now.
4xranger
1992 ranger wit
after paint this is what i ended up with, used dupli color roll in bed liner on bumpers and fenders. painted with dupli color pre mix paint , brilliant silver and jet black with gloss clear.
4xranger
1992 ranger wit
well still in the need of parts.
windsheild, door and window weather stripping, upper and lower ball joints, locking hub conversion, detroits front and rear with 4.88 gears and some interior parts to finish out inside. complete rollbar fabricate rock sliders and of course mud flaps that can be taken off when out playing. :icon_thumby:
all comments and other suggestions on build are appreciated thank's everybody looking forward to what every body thinks. :icon_thumby: / :dunno:
4xranger
1992 ranger wit
ok so i figured out how to post pic's so i have revised my build thread, so here's some better pic's and build info.:yahoo:
nb11
South Georgia
2.3l
Awesome work man, that thing is too cool! I'm loving first gen's more and more, especially after seeing this thread. And I wondered how good that duplicolor premixed stuff was. Looks great! :icon_thumby:
disciplerocks
July 2011 OTOTM Winner
Evansville, IN
Damn man, you cleaned that thing up nicely. That is one badass B2.
I'm thinking an ORTOTM nom. Post up a pic of some off-road action.
i think.....i'm in love.....
i'm going to find me a b2 to build for strictly offroad like right now!
