Bye,Bye A4LD...5-Speed in???????????????
dabwid
85 Bronco II. 2.8L 85,000 org. miles. Know the history. I am second owner. Put in a rebuilt A4LD 1500miles ago. Front seal gone already. No warranty left. BTW this is third tranny. How hard to swap to 5 speed?
TheOne
Edmonton, Alberta
clutch pedals, master (attached to pedals), clutch fluid line, manual tranny (m5od is best), 4L clutch, starter, and flywheel, ummmm alittle wiring for neutral safety and reverse lights.
Ever do a clutch or replace an auto? Its not too much harder.
dabwid
I know the basic's. Have a couple ?????? Who has done one this swap???
what about trans cross member? rear drive shaft? What years are best for pedal assb.?
kunar
Odd One
Toledo, Ohio
if youre taking out an a4ld, your trans cross member and drive shafts are just fine how they are, wont need to be swapped. the pedals need to come out of a 1st gen, thats all
if you can swap a transmission, you can do this swap. the 4.0 clutch and starter are not required but they are a nice upgrade if youre buying a clutch anyways
If you go to the M5 the d-shaft and cross member are ok. A FM145 will require moving the member forward and a longer shaft.
The pedals can come out of any 1st gen. if you are already buying a flywheel and clutch, get the 4.0 parts. much nicer.
kunar
Odd One
Toledo, Ohio
thats true, thanks for pointing that out. i guess i just dont see the mitsu as an upgrade lol
Will
Columbus, Indiana
Yep, this is exactly the problem everyone has on the A4LD and you got screwed because your rebuilder doesn't know about it. They just slap new soft parts in.
>>LINK<<
Now, if you really want to swap in a 5-speed, you are going to need enough parts that the only viable option is to find a donor vehicle. The list of stuff you need is long. If you are going to bother, it would be good if a 4.0 were attached to the input shaft of that 5-speed.
For the work and money, and since all of your A4LD parts are basically new, send them your bellhousing is the best bet.
While the M5 is superior to the FM145, I got many miles and years of reliable service out of mine. I was actually a little sad to see it go (my fault) especially because I loved that shifter. That said, a Fred Flintstone trans would be an upgrade from the A4LD.
Yabba Dabba DOOOO!!!
IlovemybroncII
greenville sc
198
Chev
For
what are you going to do with the old a4ld pm me if you want to get rid of it
TheOne
Edmonton, Alberta
what u mean u can only used the gen 1 pedals? could u not use the gen 2 pedals aswell? like from a 89 bronco?
trail B2
North Eastern Ca.
When I did this it wasn't to bad and well worth it.I have gen 2 peddles in mine m50d tranny lined up everywhere front back.I used this time to put in a 4.0 if you can find a good donor do that.I'll bet that I walked 20 miles for that A4LD loosing fluid out the front seal and it took a while but I trust my B2 again.
TheOne
Edmonton, Alberta
ok so the gen 2 pedals will work? i think my m5od is the earlier version (not 93 or 94) probably 91-92 since the slave is different than on my dads 93 ranger...
turner little
what if i have a 98 explorer for donor will the petals work or can i buy the petals
I dunno if the 98 Ex pedals will work.
If you really can't find a set of manual trans pedals for a 1st or 2nd gen PM me, I know where I can find a few good sets at the local junk yard.
rangerman84
sylva nc
2.8 v6
im actually thinkin of doin this same swap my dad did it to my ranger and i got the 4 speed automatic in my bronco II and its slippin bad but he told me it was pretty easy
