Code reader plug????
Meshell
I have a 1990 bronco2 need to know where to plug in my code reader! Please
NW Arkansas
The connector is located on the right side (passenger's) side of the firewall near the strut tower. The operation procedure is listed in section 6-2 under EEC-IV system trouble codes. in the Haynes Ford Ranger & Bronco II Automotive Repair Manual 1983-1992 The book is 36070 (1026)
Dennis
Meshell
Dennis
Thank you for your reply. I located a box in the area suggested but ( I know this sounds dumb) can't figure out how to open it if it opens, or how it plugs in without breaking the box that says EEC test. Any suggestions?
There should be a cover that the connectors clip into.
Meshell
There is and I located the clip am worried I will break it the plastic is brittle from age ok I will just jump right in and hope I don't break it. Thank you for your help.
