drum to disc conversion
LeBronCo
North County San Diego
1987 and 1986
Life is more fun if you own a Ford Bronco II
Does anyone know of a rear drum to disc conversion kit? Looking for simple bolt on; no machining.
duffy
A later year of 8.8 rear end with discs would be the easiest......
LeBronCo
1987 and 1986
What models would have an 8.8 rear end? Ranger and Bronco II 1990?
LeBronCo
1987 and 1986
I read here that '96-01 Explorer has an 8.8. Off to Pick a Part I go!
dirtcowboy
NW Montana
2.9, 4.6, 4.0, 6.8, 5.0x4
Any explorer 91? to 96 has an 8.8 disc rear. They are about 1 1/2" total, 3/4" per side wider, not a huge deal.
McWillies
Louisiana
2.9l
Make sure the rear end ratio is the same if your truck is 4wd. Sounds simple but easy to overlook.
LeBronCo
1987 and 1986
Do I need to make any adjustments to the drive shaft and spring/shock mounts, or is it a direct bolt in ?
