EXHAUST HELP
Brooksie1911
Ford bronco ii
So I took the cats off my bronco ii, trying to straight pipe to a muffler but I can’t for the life of me find an oval adapter to fit where the cats were please help me this has been hell
Mine had gutted cats when I bought it. I would not recommend going without cats after having that experience.
"Choking exhaust fumes" is the way I would describe it.
When I had the exhaust redone with aftermarket cats it didn't lose any power.
For "offroad purposes only", you could just cut the flange off and use a sleeve to go straight pipe to straight pipe or you could gut the cats you have and bolt them back on.
Brooksie1911
Ford bronco ii
Brooksie1911
Ford bronco ii
Thanks for the reply, ya this is my trail rig, I don’t know if I could stand the noise driving this daily lol
tw205
Bronson michigan
For “off road purposes “. A 3” exhaust pipe with a bell on the end works. Squeeze it to oval and it will slide over the oval end of the Y pipe.
Brooksie1911
Ford bronco ii
What do you mean by “bell”
tw205
Bronson michigan
If you purchase a small section of exhaust pipe off the shelf at the auto parts store, one end will be enlarged to allow it to fit over another pipe. If you buy a 3” diameter pipe, it will be 3” outside diameter and the bell end will 3” inside diameter.
I had bought a 3 inch to 2 1/2 inch exhaust adaptor. Put the 3 inch end in a vise and smashed it to an oval as stated above... then welded it.
Brooksie1911
Ford bronco ii
Sick, I’ll try this thank you
