M Meshell New member Joined Jun 20, 2017 Messages 21 Reaction score 3 Points 3 Vehicle Year 1990 Vehicle Ford May 9, 2022 #1 Advice on ignition switch replacement
XTC90BII Active member U.S. Military - Veteran Joined Jul 24, 2016 Messages 344 Reaction score 39 Points 28 Location NW Arkansas Vehicle Year 1990 Vehicle Ford Engine Size 2.9 Suspension Style 4wd My credo Do what you can with what you have where you are May 10, 2022 #2 It's that thing on the right side of the steering column where you insert the key. Dennis
Uncle Gump Moderator Forum Moderator Joined Mar 4, 2020 Messages 543 Reaction score 206 Points 43 Location Ottawa IL Vehicle Year 1986 Vehicle Bronco II Suspension Style 4wd May 10, 2022 #3 @Meshell you need to clarify... Ignition module Ignition switch Entirely different components.
M Meshell New member Joined Jun 20, 2017 Messages 21 Reaction score 3 Points 3 Vehicle Year 1990 Vehicle Ford May 19, 2022 #4 Uncle Gump said: @Meshell you need to clarify... Ignition module Ignition switch Entirely different components. Click to expand... Yes I know I ended up replacing the relay. Thank you for your courtesy
