In need of a lock actuator
3Stgs
I have looked everywhere for a door lock actuator for my ‘86 Bronco II to no avail. Everything I’ve found is for an 88-90, and it comes with multiple arms. I believe the one on my actuator is fixed, and not sure what else might be different. I can’t even find a used one online. Any help or advise would be great.
Bronco Graveyard has some I think.
3Stgs
I tried and they do not have any for an ‘86. Also I cannot find any information on what the difference is between the earlier version that is ‘87 and older and the ‘88 and newer ones.
3Stgs
Well I guess I’ll roll without power locks for a while. I do have a question relating to wheels, I have ran across a few sets of Ranger wheels that I like but I’m not sure the backspacing/offset will work, I’ve used an offset comparison tool and the ones I like sit about 15mm closer to the suspension components, while the outside of the wheel is virtually the same distance as the one now (prob the 1/2” difference from a 6.5 to 7” wheel). It’s a 16x7 ET12 wheel. Any input?
bronco2_tx
Bronco II XLT
I have an '87 and facing the same issue now. My passenger door lock froze out of nowhere and I could not even lock manually. I took the old one off and the end of it is different from anything I found online. Went and pulled one off of a '90 B2 at junkyard and noticeably different. All of the motors are the same but it is the linkage that is different. Part number for my '87 Passenger door reads: E77F10218A42-AA.
There is a salvage yard near me that has an XLT B2 I bought the tail gate off of. It had power locks. I think it was an 86 because it had EFI but had the early dash and grille etc
3Stgs
Those from the above link are some type of universal deal, I don’t think I’d recommend. I’d like to buy new placements rather than used, there are inexpensive aftermarket units on eBay that look exactly the same as OEM with the same mounting bracket and connector, and have replaceable arms. I can’t imagine what the difference would be that would make it an ‘88 and after-only application. Think I’ll order one and try it.
3Stgs
Could not make the 1988 actuator work. How is it that no one has this part?
Having an 86... with currently functioning power locks... this concerns me because they don't work forever.
Is it possible the change to the newer latch AND lock actuator.
3Stgs
That’s a good suggestion, I haven’t looked into it. At that point you could use the 1988-90 actuators, I’m not sure how involved the swap would be.
bronco2_tx
Bronco II XLT
I found an NOS lock on eBay that was listed for an ‘87 Ranger and could tell from the photo it matched mine. Bought it and put it on and works great again. You will need 1/4” rivets for reattaching and can get the tool at Harbor Freight for under $20. Attached is what it looks like out of door and installed.
bronco2_tx
Bronco II XLT
Yea that is definitely different and based on part number was mfg in 1985. Maybe it was different through late 1986?
3Stgs
According to the Ford parts list it is for Bronco IIs “before 11/87”. But there must not be enough demand to mfg an aftermarket unit. Threw my OEM units away assuming I could get them aftermarket, since I could get pretty much everything else. 🤦🏻 Guess I’ll keep looking at the used parts searches…
bronco2_tx
Bronco II XLT
Yes that’s what I had seen so thought all before 11/87 were the same as mine. They have aftermarket ones with several different configurations but did not see one that matched mine.
LeBronCo
North County San Diego
1987 and 1986
I saw one in LMC truck catalog. It says '87-92 but there's a diagram of the one they offer. Hope that helps.
