New Front Rotors
NW Arkansas
Looking to replace the front brake Rotors on my 90 BII. I checked at Bronco Graveyard and I think I need part number 92514 which calls for axle code 44 and 3.73 axle. I know I have a 3.73 limited slip rear axle because I have decoded the rear axle tag. However I cannot find and tag on the front axle or anything that gives the ratio or any codes. Am I correct to assume the front axle ratio is the same as the rear axle?
Help Please
Dennis
buck119fa
Michigan
the gear ratio should be the same unless someone swapped it. there are cheaper places out there to get the rotors, even auto zone should have them. I ordered mine from buy brakes .com as a kit with the pads and wasn't too pricy.
NW Arkansas
I broke the code. A code 44 front axle means you have a 3:73 rear differential but it is not limited slip. It is an open differential (non limited slip) So I have a 3:73 axle code DX limited slip rear differential which means I have a non code 44 front axle. Now I know which rotors I need to buy Thanks everyone for the help in figuring out which rotors I need.
Dennis
NW Arkansas
Update
As it does turn out I do have a code 44 front axle. I had to return the non code 44 axle rotors and reorder the code 44 with 3.73 rotors. Now I know. I needed the 2.458 inch in height not the 2.17 inch.
Dennis
