Newd help with 86 bronco 2 ..
86B2shitbox
Bronco 2
So I just got my 3rd bronco 2 an re did the head gaskets on it...runs great.....when its running you put your foot on the clutch doesn't make any noise,,but when you put it in any gear it bogges the engine down.??? Any thoughts...thnx..
This is with the clutch pedal to the floor? It doesn't grind going into gear?
86B2shitbox
Bronco 2
Yupp clutch is to the floor..an theres no grinding at all..goes into all gears fine but kills the motor ..
dead kill , or chug-chug die?
86B2shitbox
Bronco 2
Dead kill it...if I keep it reverse up an then put it in gear it will bog down an run like crap..I'm gunna do fuel filters an good plugs today,, then jack up the rear of the truck an see if the tires try to move.
