no power under load
LeBronCo
North County San Diego
1987 and 1986
87 2.9. Checked all sensors, spark, fuel. Found rust in tank so replaced tank, sending unit, both pumps and filters. Checked injectors; ok there. Here's what is happening. It starts, idles and revs fine. Pulls away in first gear ok. Second, plus/minus ok. Third gear with a little incline and it feels like its plugged up. Will not pull. It feels like it fires unevenly almost like it's only running on 4-5 cylinders. Forget fourth gear. WTH?
Bronco
Is this the same truck you've been working on for a couple months?
Have you checked for restricted exhaust?
LeBronCo
1987 and 1986
Yes it is. I had to wait for parts. I initially ordered the tank, etc. from LMC. I called after 2 weeks and then I was informed the tank was on back order so I went to Rock Auto and had everything in 4 days. I was thinking a bad cat. I watched a video on YouTube where a dirty MAFS was the problem. The tricky that about this one was the MAFS was giving off a good reading. I'll check both and see if either one help.
Bronco
Well good luck...
A plugged cat is fairly easy to diagnose... google testing for restricted exhaust with vacuum gauge.
