oil pan
iggiedog
hello everyone. new on the site. I have a 1984 bronco II that I purchased and it already had the 302 conversion done. while under the bronco changing the oil I noticed the oil pan is sitting on part of the suspension. I have looked for an oil pan used for the 302 conversion but had no luck. I took a quarter inch shim on the driver side engine mount to lift it off. it still touches but not as bad. does anyone know where I can get an oil pan that will work. the oil pan on the bronco looks like a double sump pan for a fox body mustang. if there is no such oil pan im going to have to try and cut and modify the oil pan. any suggestions. it is 4x4 if that makes a difference... thanks all
bronco2fan
Ft. Hood, TX.
Almost everyone uses the dual Sump pan on 302 conversions and there's no problem. You have to because of the way the front axle is. You may have bad or home made Engine mounts and they're not doing the job. Checkout James Duff and see what they're using.
iggiedog
Thank you I will check with them
