Picking up my next B2 Project
buck119fa
Michigan
I'll be picking my new find tongiht :yahoo: Base model 1984 B2. very little rust, no holes anywhere yet, 55k on it, drivers seat is the only bad thing in the interrior (not that it matters, it's all getting changed). Beige with a tan interior, that has to go. I'll post pics of this later. Many upgrades to come on this one, it's a good solid truck to make a project out of and the price was better than right!
Starting with the interior, total color change, new gauges, stero equipment, new front buckets and I'm sure other little things.
Next will be the body work (what little there is) and a good paint job. then the motor is getting the duraspark swap
last will be the suspension and axels with some new 33's.
I'll get the pics up later and I might start a build thread on it since I'm doing a complete build in and out, all but the motor swap (that comes much later.
Here it is, just got it home. more pics in my profile
buck119fa
Michigan
After getting this in the Garage tonight and really going over the body I'm impressed.
Looked it all over and found "NO" rust holes in the body, surface rust here and there but I've see worse on newer cars. The radiator support is solid ( i was supprised) wheel wells are solid, floors, mounts, just over all nice. the only real rust was at the bottom of both door seams but nothing that can't be cleaned up and sealed.
Tomorrow I'll start removing the interior and start off with that work.
88B2EB
Detroit, MI
2.9L, 2.3L
Welcome to the forum from another Michigan guy.:icon_thumby:
Looks like you have a good clean Bronco to start with. I was surprised you found so little rust, especially with Michigan roads being what they are. Usually when somebody paints the bottom black like yours is they're trying to hide something so again it sounds like you really lucked out.
The restoration work on mine's just about finished: http://therangerstation.com/forums/showthread.php?t=128403
All I can say is stick with it. It's a lot of work and can get hard to stay focused but is definately worth it in the end.
Josh
buck119fa
Michigan
Thanks, yea the black paint was hiding paint bubbles, little rust but nothing thru the metal. this belonged to a a friends mother, had it since it was new, explains the mileage, it was undercoated too.
This will be my second project B2, first was a 90, wish i wouldn't have sold it. Started this one tonight, few hours, few beers and my boys help we have the interior striped for cleaning, repainting and whatever else we find it need, like stereo speakers and a;ot of upgrades. Should be a fun project now that the boys are old enough. Heck their going back and forth on who gets it when were done.
buck119fa
Michigan
Havent been on in a while, work on the house has taken prority over the Bronco build. Just an update, interrior is almost complete (post pics later) and just picked up both my new axles for the upgrade, dana 35 from a 94 explorer and a 8.8 from an 03 sport track. going to start going thru both and replaced bearings, seals and u-joints. Now to get the suspention kit and get these installed.... that may be a little bit.
buck119fa
Michigan
updates to this build
Well I haven't been on here in forever but thought I'd add some updates.
Body work is complete and painted, body lift is on, interior and wiring is done, sound system is in. starting to get things together for the suspension, looking for the bumpers I want. Got a screaming deal on wheels and tires for it. Still assembling the exterior but with the cold weather I've stopped painting trim parts and such. Probably start on some motor work this winter and get to the rest of the painting and such in the spring. Still looking for gray interior panels for the whole truck. Painting is fine for now but would like to get it all replaced. I'll add some photos shortly, Big change since I picked it up. Just not in a big hurry to finish it. but I have my eye on a couple more Bronco II's that I'd like to get my hands on
buck119fa
Michigan
A lot of changes for the base model it was. Lots of scrap yard hunting to find stuff, Craig's list finds. Still shopping for stuff however. this was the base model, nothing extra. First I gutted this interior out, found some rust at the rear hatch so I replaced that section of the floor. got the body work done. repaired 1 rust hole behind the passenger door. other than that only a few dents to fix. Filled the holes for the tire mount also (that wont go back on). Added the 2 inch body lift, Added the roof rack, found the heat duct for the rear seats and got that in, added the front seats from a 2000 explorer and used the material from the rears to recover the stock ones to match, added the counsel, new carpet and headliner, all the interior was painted charcoal gray. installed the rear window defroster, new stereo system, sound mat on the floors, inside the doors and rear panels. replaced the interior lighting front is out of the 2000 explorer and added a rear cargo light(didn't have one) out of an expedition (has 3 position switch, on, off, on with door open). replaced the sun visors with some out of a 2004 ranger for color match and these have the vanity light and mirrors. Have a NOS sun visor to install on the roof yet. tinted the door windows and added tint to the rear sides to darken them up. currently smoking out the marker light lenses and getting all those changed over to LED. still a lot more to go but it's progress.
buck119fa
Michigan
body and interior work
here are a couple pics during the body and interior work
buck119fa
Michigan
after paint and interior
some pics of the finished paint and interior
IckesMan5150
Brookings, OR
2.9 Liter V6 Auto
Use what you have to its full extent and have fun doing it.
All I can say is WOW! you have done so much work on your B2, I'm really impressed with the outcome. I wish my stamina and energy on my truck was somewhere near yours. Good job.
buck119fa
Michigan
Thanks, been 3 years on it so far, still have a lot to do with the suspension, bumpers, and some motor work. Hope to have it done this spring, time and money, just keeps adding up but it's been worth it, lots of time with my boys on it, the boys helping makes it all worth it.
Vstromvoyager
Great looking truck! keep us updated with any progress. I just picked up an 88 Eddie Bauer to work on and I just trying to get a game plan together on it. BTW what size tires and wheels did you go with, they don't look like 15".
buck119fa
Michigan
Thanks,
tires and wheels, 31x10.50x 15 on MB TKO wheels 15x8 -19 BS.
Working on the Dura spark conversion right now. Waiting on parts to come in. I'll post pics and such when I get that moving along.
buck119fa
Michigan
Started the Duraspark conversion this weekend. All the parts came in so got it all tore down yesterday and spent most of the day working on the exhaust. once I pulled all the garbage and the smog pump I didn't like the idea of just plugging the hoses so I removed both exhaust manifolds, cut the tubes and welded in a bolt as a plug, all new manifold bolts and gaskets, getting some extra brackets/junk off took the better part of the day. Still have to plug the tube on the converter, left in the O2 sensor just removed the wire. Cleaned up the valve covers and painting those today, made the block off plate for the EGR. I'll start the wiring later today and try to get it running maybe tomorrow. Couple of photos attached
Vstromvoyager
That pile of wires and stuff is pretty crazy looking. Along with the 88 I have an 84 I work on and have been thinking of doing this mod on it. Keep the pics and progress going!
buck119fa
Michigan
Updates
Finally got the duraspark conversion done today and a few other upgrades (pics below), too many other things took priorities again so it took a little while.
So, the conversion wasn’t too bad, followed the info in the library with a little change. I went with the GM ignition mod instead of the duraspark box, little extra wiring to run and less used out of the trucks harness. All the parts were bought thru Summit Racing. While I was at this I eliminated the converter and just put in some straight pipe. Put in a single wire 100a Alternator, once the smog pump is removed during the duraspark the belt was long so I figured why not… by the way the power steering belt is exactly the same size needed for the alternator after removing the smog pump. Also installed an electric fan with the thermostat control on it and it can also be wired to a switch. Will be adding a second battery for the accessories (new fuse block is wired and in waiting, on the fender well)
Going on vacation in about a week and will be stopping to get my suspension lift, front prerunner winch bumper and rear tube bumper with the tire carrier from James Duff. Looking forward to getting that all done and be able to start driving this,.
buck119fa
Michigan
Update, Well we made a trip to James Duffs shop a couple weeks ago, got the new bumpers and suspension lift. starting the lift now, just got the bumpers fitted and powder coated. Figured since I'm putting in the D35 I'd rebuild that and get it powder coated also. progress... got the rear springs and shocks in tore out the front end last night. More pictures to follow but here are a couple of the bumper fitting and axle .
buck119fa
Michigan
It's coming togeather. still a lot to get done but the lift is on.
shadetreebronco
CT
Hey thats a great looking truck , Keep us posted .
