10/16/15 Update
It been awhile but...
I've been busy working away on this OBS RBV POS 1986 Bronco 2.
This past May my fm146 blew up again after 3 prior doctors appointments at the local transmission shop. I had done enough reading online and eventually early august i ended up buying a 1993 explorer to harvest donor parts for. But ... between May and August i worked on my crippled horse and got some shit done.
-I insulated the hell out of my truck. My rear quarter panel was split away from floor, from the right side wheel well back to the tail light. So it was an 18inch or so split which was right above my 31" all terrains which made for a mess. But anyways i pulled out all my interior, sprayed the floor black with bed liner, and then i used the combined force of loctite outdoor adhesive, silicone seal, JB Weld, and Bathroom Caulking to seal the split between the body panels. I then found some real thick old pool personal foam rafts that were from an old lake house. I cut these up with a K-Bar and stuffed the foam pieces into the body panels mostly in the back. Then i cut and used spray adhesive to attach foam aluminum sheets to every surface that i could stick it to. I gave all my interior panels a temporary coat of black over the 80's red plastic.
-I went to the junk yard and pulled an aftermarket sunroof off of a grand prix for 55 dollars. Saw zaw in hand and with the cut once measure once mentality i chopped a big ol hole in my roof. Dropped in my power sunroof after running a bead of silicone seal(it doesn't leak). I would sit in my broken truck and just open and close my new sunroof. Also my roof was unattached from inside so it would make all kinds of sheet metal noise when just driving around so i went in there and caulked and stuffed foam wedges between the roof supports and the roof.
-I did metal fab and i fixed up some of the issues with my custom made bumpers. I chopped up the rear bumper brackets and pulled in my rear bumper 2 inchs, made some custom brackets which tightened up any play in the attachments. Then for my front bumper i chopped up the grill guard that i have because it was pretty damaged and bolted to the front of my bumper which i didnt like. I did some pretty cool custom work and attached it to the frame behind my front bumper, so it fits real tight to my grill and its sturdy. It looks awesome.
Bought this 1993 4 door, auto transfercase, manual hubs,explorer for 500 dollars running and ripping. Its a rusty SOB but the owners had it serviced at the dealership every 10k with 180 on the 4.0. The m4od had just been serviced with all brand new seals and parts... perfect donor truck.. After beating it to hell for a couple of days i tore into the explorer and pulled my first engine and transmission by my 19 year old self in the drive way with 2 jack stands and a floor jack. I stripped everything i needed off that thing in about 5 days.
Anyways the m4od is attached up to my 2.9, in the meantime i am going to go over the entire 4.0 while its out of the truck and do her up all real nice, maybe a ford blue. But then drop her back reuniting with the m4od. Until then my 2.9 with 108k on it leaks oil, burns a little bit of coolant, has dual manifold gasket leaks, has an often idling issue where it bogs itself down and chuggs then comes back to an idle. Oh and i forgot to mention how the m4od doesnt fit perfect in the bronco 2, it requires a automatic transfer case,transmission mounts relocated and two new driveshafts. So right now im running 2wd with no front driveshaft and my maunual transfer case is locked in 2wd with no shifter.
I'll put up some pictures of all the above here soon
