Shocks needed
Redlazer
My 90 B2 is in bad need of shocks. It is not jacked up or anything. I was thinking of JBG shocks, or Duffs shocks. Are either ones of these good? The JBG are $36 a shock, and the Duffs are $37 a shock. Or is another brand I should go with? On my SD, and Mustang I only run Bilstein.
I put monroe-matics on mine, see my thread. They are soft and give a good around town ride. They will bottom out in the back on really big bumps,
Ideally I'd like them maybe 10% stiffer at three quarter to full compression.
I'm interested to hear what others like and how you like the shocks you end up choosing.
Redlazer
I’m still not sure I’m leaning towards the JBG right now.
NW Arkansas
I wanted to stay completely stock so I went with OEM MotorCraft shocks. The B2 has never gone off road and the ride is fine on the highway.
Dennis
Redlazer
Yeah I use my B2 for hunting. I may get a 4in lift for it.
MoyaBros
Bronco II XLT
what did you end up going with? I'm redoing all my suspension bushings and thought about a lift........ another member recommended staying stockish with out lifts as im only running 30x9.5x15
Redlazer
Well as of right now nothing BC I’m saving the money to get to Duffs stage two suspension kit.
wend3lrt
Ga
Bronco ii
The Monroe shocks are good and not too stiff.
duffy
I like Rancho's for mild off road use (hunting), good on road ride also.
Cees Klumper
Bronco II 2WD
KYBs on mine, very good shocks and around $35 each.
