towing 89 bronco 2
russred89
2broncored
89 broncoll
I have an 89 Bronco 2 with manual transmission and transfer case I want to tow on a tow dolley .If I put transmission and transfer case in neutral should I still disconnect drive shaft at rear axel?
duffy
I haven't looked in my OM yet but it should give the procedure in there.......my 89 has an auto trans with an electric shift trans case with manual hubs and I think I could tow it by just getting the trans case in neutral (I understand you have to remove the shifting motor and manually select neutral). It might be different with a manual transfer case.
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
Transmission in gear, manual transfer case in neutral. Electric transfer case has no selector for neutral.
duffy
Yep, I checked my OM and if you have an electric shift transfer case they say to drop the driveline.
