What other carburetor?
Brutal6
85 B2 durasparked with the carburetor from a 1978 Pinto 2.8, 1.08 venturi. What other MOTORCRAFT 2 bbl carburetor would be a bolt on replacement?
Can anyone recommend a carburetor repair shop that can rebuild/repair the throttle shaft bushings? If so please let me know.
TIA
B6
Broncotim
Tennessee
I did the dura spark conversion several years ago on a 1984 Bronco II 2.8l. I used a 1978 Pinto Distributor and Coil and a Holley 3500 2barrel carb manual choke. I had to change the jets to smaller ones. I can't remember the size. Found the information I believe in the Tech Library. Ran great.
Brutal6
Was the Holley 3500 a direct bolt on, even the throttle/kick down linkage?
Thanks for the reply
Broncotim
Tennessee
Yes it was direct bolt on and the linkage connected correctly
