1984 Bronco 2 - Sat for 15 years
ErinBronco2
Wisconsin
Ford Bronco 2
My first vehicle was a 1989 Bronco 2. It had deep red interior and a 4.0L. I loved that truck, but it was 2010 and I think that's when gas was in the $4 a gallon range. I traded it for a Jetta that leaked gas into the oil and ended up getting about the same MPG anyway. I've regretted that ever since.
So last year my dad found a 1984 Bronco 2 for sale for $500 a few hours away. Apparently it sat in a barn for about 5 years because the starter went bad and the owner never fixed it. Then that owner sold it to someone else where it sat in a field for 10 or so years. We drove out to look at it, and it looked pretty rough. After we found a few nasty things (the carpet was soaking wet front to back), the guy asked for $400. I think the seller and I both walked away thinking the other guy was a sucker. So we towed it home and it sat outside again for 8 months over winter.
14723
14724
In spring, I finally started working on it. First thing I did was pull the carpet. The carpet was wet because of a nice little hole on the roof.
14725
14726
Next, we chased down a few brake line leaks. And by a few break line leaks, I mean that we literally replaced every single brake line on the truck. Also completely redid the back drum brakes and put new pads upfront.
14727
14728
We also did the Duraspark conversion. I was mostly along for the ride while my dad did all the work on this. I've got a good idea of what he did, but FYI it wasn't really me lol
14729
14730
New plugs, new wires, new distributor, etc. Finally got it running at this point. I drove it home about 15 miles away and noticed it didn't really like going from a dead stop. When I finally mad it to the house there was smoke coming from the front driver side wheel. The caliper was stuck on and the brakes had been on the whole ride home.... which explains my interesting ride home.
So of course, new wheel bearings, new front rotors, new brake pads, new calipers and at this point the only two things in the entire brake system that aren't new are the master cylinder and the proportioning valve. Sorry for this bad picture of a wheel with a shiny rotor.
14731
I drove it like that for a few weeks. It's been taking a solid 15-20 seconds of cranking to start. So next on the list is a gasket kit for the carburetor and I'll do a complete rebuild/refresh.
Also, I noticed it kinda stunk. Nothing crazy just had a nice little musty smell to it. I was working on the radio when I pulled the driver side rear speaker and was HIT with a wretched piss smell. I could see a rats nest behind the whole rear panel :bad:. So one fine day I pulled that panel off and got a good look....
14732
ErinBronco2
Wisconsin
Ford Bronco 2
Definitely don't wanna put groceries in your trunk after you've seen this....
14733
14734
Of course after I pulled this panel off, I pulled the other side off and found it wasn't quite so bad, but still nasty over there too. Found that the rats/mice also made it up to the headliner.
14735
So the headliner isn't going back in. I'll figure that out in the future, but MAN did that thing stiiiiiiink. After a three days of hell, it's finally "clean". Everything I could find has been pulled out, vacuumed, bleached, vacuumed, febreezed and then bleached one more time for good measure.
14736
14737
14738
Then put her all back together....
14739
And took someones recommendation to fix a loose hatch with some PEX pipe! It actually works amazingly well, but we'll see how long the plastic holds up.
14740
Here's some bonus pics of the bad rust spots and a 20 year old spare tire that is stuck on at this point. I could cut it off but don't have another spare to put on, so I'm just gonna leave it for now cause it looks okay lol
14741
14742
ErinBronco2
Wisconsin
Ford Bronco 2
14744
Front suspension. Plan to get new shocks, tie rods, and bushings up here as soon as I can afford it. You can also see she's got a slight leak from up top (already replaced driver side valve cover gasket which did wonders).
14745
Here's the engine bay as she sits now.
14746
14747
There also seems to be a nice melted hole in the heater box. Sorry for the weird angle, it was hard to get perspective for this shot...
14748
Bonus shot of my dad's beast.
14749
Here's a video of mine idling.
So there you go. You're all caught up now.
Things for me to do:
  • Carburetor rebuild
  • New carpet
  • New headliner
  • New shocks all around
  • New tie rods
  • New bushings for front suspension/steering
  • Figure out the ticking as seen in video above
  • Replace passenger side valve cover gasket to address slight leak
  • Figure out transmission fluid leak (very small)
alwaysFlOoReD
Blang - not bling
Red Deer, Canada
'91, '93, '98
Various
Looks like you're well on your way to a great truck. I had a similar year b2 but with a whole lot more rust. Your floors look surprisingly good.
Administrator
Administrator
Founder
Roanoke, Texas
Wow, you have your work cut out for you.
BabyBroncoDave
Wow looks great! Cant wait to post mine.
ecgreen
New Hampshah
Diggin the thread! Keep us posted
wend3lrt
Ga
Bronco ii
Looks like there's a lot of rust underneath. Good luck! Looking forward to seeing more updates and pics.
ecgreen
New Hampshah
Not a lot of rust by northern standards. If you can't break a hole in the frame with a hammer its good to go IMHO. With mine I wire brushed the scale rust off and used Eastwood rust encapsulator followed by a blac top coat.
ErinBronco2
Wisconsin
Ford Bronco 2
Yes, the floors are okay... for now lol. I still need to bondo up the whole on the roof.
Surprisingly not a ton of (destructive) rust on the frame/underside. Obviously it's rusty, but there aren't big holes or giant flaky patches really.
Anyway, I've had a busy summer with this truck. First thing first, I had to rebuild the carburetor. I was having major issues getting the truck started from cold. Like hold the key for 15-20 seconds before it would turn over issues.
Here's some before shots:
14782
14783
14784
14785
14786
14787
14789
14788
ErinBronco2
Wisconsin
Ford Bronco 2
And here are some "after" shots. I still need to take some pictures of the carburetor in the truck.
14790
14792
14791
14793
Then of course, I ordered a rebuild kit. And then of course.... I opened it to realize it was the wrong kit. Sort of.
14794
14795
14796
So then after waiting another week for the new kit, I found out that maybe it wasn't the wrong kit. I think someone had already "rebuilt" this carburetor, because some of the gaskets didn't match any of the kits. . Idk. I got it eventually but it's been a while since I rebuilt it. I'm pretty sure I discovered that it had a 1984 Bronco II gasket on top, and then a 1980 f-150 power valve. Something funky like that.
14797
Here you can see I tried to use a paper clip in place of the original metal bar. Becauuuuuuuse. The stupid bar was an S shape insted of a U shape, where the ends faced opposite directions. But it clearly needed to be the U type where they both face the same way. I'm not sure how the hell it was originally installed, but it was wrong.
14798
14799
I ended up using a torch to get that piece real hot and twist it the right way. Worked out well, will need to post a pic of that later.
ErinBronco2
Wisconsin
Ford Bronco 2
14801
14802
The top gasket I ended up using. It doesn't match the original 100%, but looks pretty much right.
14803
Here it is all done.
14804
I will post a full "after" shot in the next few days. I've also done a few other projects besides this, that I need to take some photos of. That's all for now folks!
ErinBronco2
Wisconsin
Ford Bronco 2
Notice anything different???
14805
Look at that shiny new carb!
14806
And what's that?? A no A/C heater box! With no hole!
14807
But wait! There's more! A new power steering pump!
14808
Soooo pretty
14809
So next up, I'm looking at shocks and tie rod ends. Also need some new window belts / weatherstrip to make winter a little more tolerable.
ErinBronco2
Wisconsin
Ford Bronco 2
You got quite the project there.
Quiiiiite the project.
So, I ordered the window belts/weatherstripping. I am still working on this project, but here's a shot of the door without the door panel and a shot of the other side with the panel. Just for the sake of documentation.
14815
14816
I replaced the shocks this weekend with the help of my dad and his lift. You can see the new brake pads/rotors/calipers/lines here too.
14817
14818
Beauty shot
14819
Here you can see the rear shocks and the new tank too. The underside is not in too terrible of shape as I mentioned earlier.
14820
The transmission and oil pan both have a slight leak.... that's a project for the future. Sorry for the weird angles. It was hard to get a good perspective standing under the truck.
14821
14822
Here's the front end. Next month, I plan to replace all of the tie rods. The driver side outer tie rod is toast. Or at least looks toast.
14823
When I get my window seal project wrapped up, I will post more thorough pictures. I had a hard time finding info for it, so hopefully that will help people in the future.
NW Arkansas
Very Nice
Dennis
ErinBronco2
Wisconsin
Ford Bronco 2
The Bronco II is still alive and well boys. I'll post an update soon. I've had some issues related to the cold weather, but she is still chugging along.
duffy
Have you found a source for a new headliner? Mine is missing all the cloth.
duffy
I found the solution......re-cover it. Watched a u-tube video and it looks easy enough. Gonna check on material Thursday.
