caseygriff
- Sep 18, 2023
- 13
- 1
- 3
- Age
- 22
- Huntington Beach, CA
- 1987
- Bronco II
- Suspension Style
- 2WD
- My credo
- Workin hard or hardly workin
What's going guys I'll be brutally honest because I need some help here. My fuel gauge on the dash was functioning fine after running some techron through a few months ago. It was showing decent enough somewhat accurate readings until a few weeks ago I noticed it sitting at empty even though I had about 1/2 tank or more. This is what got me into trouble, I drove her a bit too starved of gas and managed to make it home and park. Was jerking and surging due to low fuel for the last half mile or so. The next day I went a filled a couple of jerry cans and refueled expecting no issues. Wrong again, the B2 died as soon as I got around the block
Would fire back up and drive for 300 ft then slowly lose power. Pushed her home thanks to the help of some neighbors. Figured maybe I starved the fuel-sending unit and burned it dry? Today I cut an access panel to inspect the true level of gas in the tank which is 3/4.. High pressure pump and filter are fresh and I can hear the hi-pres. priming when I turn ign on. Also Im getting one loud click from the starter then a series of rapid clicks. My under hood solenoid is new as of last year and the starter is old. Real odd to me is how both problems started at the same time, real convenient ford stuff My two questions are 1. how can I diagnose the sending unit beyond bench testing for resistance? and 2. do I simply need to replace the starter? Thanks
