HELP Can't get my BII conversion to start.
CORedneck
Did a 92 Ranger 4.0 swap into my 85 BII. The Ranger is my own and it ran well before I started my project. I installed all the wiring harness from my 92 Ranger into the BII except for the light harness which I kept in the BII. The headlights, turn signals and horn even works. The starter works off the ignition switch. I connected the red/green wires together like in the excellent tech library article. Everything went well until I tried to start it. There is a relay that kicks on and the fuel pump runs for maybe a half second and then everything kicks back off. The fuses in the power distribution box are all good except the one for the alternator is not getting power to it. I ran all of the Ranger harness to the engine and over to the drivers side and retained the BII plugs to splice into. Any help anyone can give me to find the problem would be greatly appreciated. I used an old mechanics trick when I put the engine in. You take some spare stock rims without tires and put them on the front axle lowering the front several inches and making it easier to clear the front radiator support.
So the fuel pump relay turning ON with a key ON cycle and back OFF is normal. The relay should then turn ON again once the ECM sees engine RPMs over 400 RPM.
What I would try is to jump the fuel pump relay and see if the engine will start that way.
I assume you checked for spark and you have it.
Here is a cut and paste from a post in another forum that may help get you going....
Do 50/50 test anytime you have a crank but No Start............on ANY engine, lawn mower to V12
50/50 test
spray fuel into the engine, i.e. gasoline, ether, carb cleaner, ect.............
Try to start
If it starts, runs and dies then you have, good/timed spark, but no fuel delivery
If it doesn't fire or start then you have no spark
50/50, instant results on where to look
The ONLY sensor that can cause a No Start is the crank sensor, just FYI, and it causes No Spark
When you turn on the key the CEL(check engine light) will come on, it means computer is powered up
When you activate starter motor the CEL should go OFF, that means Crank Sensor is working, computer is getting a timing pulse
There is one other sensor that can fail in an extremely RARE way, the throttle position sensor(TPS)
Unplug the TPS 3 wire connector and see if engine starts and runs, if TPS shorts fuel injectors are shut off
New fuel pump means NEVER TESTED fuel pump, unless its a Motorcraft, and they are way too expensive, lol
So "new part" doesn't mean "working part"
If possible test fuel pressure
I just had to change the capacitors in my 1994 computer, after 20+ years they leak and fail, under $5 to fix
So if you have odd issue it worth a look versus just randomly replacing parts that can'[t fix a computer issue
And it's free to have a look
You can see the 3 blue capacitors in this picture: http://www.auto-diagnostics.info/ford_eec_iv
CORedneck
UNCLE Gump, You are a lifesaver. Having fought the problem for days and finally deciding the problem had to be the EEC your advice saved me from the expense of replacing an unneeded EEC. I checked for spark like I should have done in FEB, I discovered I had spark. Then I took a spray bottle and sprayed a little gas past the Throttle body and got it to fire off. I then jumped the fuel pump and it ran as long as I had it jumped. The final result is everything is okay except for a fuel line problem that I will take care of when I get the new parts. In my case the fuel pump was easy to jump by taking a test light and touching it to the fuel pump terminal in the VIP test connector on the power distribution box. The information about how the EEC operated the fuel pump is valuable information. Thank you so much again Uncle Gump.
I guess I'm confused to the lack of root cause. What actually fixed your issue?
CORedneck
Taking the time to check for spark and bypassing the fuel pump relay to make sure it was pumping fuel properly fixed the issue. It was my first time dealing with a computerized engine and I ignored the basics of checking for spark and fuel. The information that Uncle Gump provided about how the EEC operated the fuel pump helped me down the right path to success.
CORedneck
Still Having Problems with my conversion. If I spray gasoline into the intake the engine will run. Problem now is fuel supply. I have 12.5 volts at the pump, 3 inches of gasoline above the top of the pump and not a speck of dirt or corrosion any where in the tank or on the fuel pickup strainer. The pump spins freely. I am on my second new fuel pump from two different suppliers and can't get more than 8 psi out of the pumps and as soon as I stop the pump the pressure goes to zero. It is possible to have two defective pumps, but very unlikely. I have a third new one coming. The only problem I can see is that because of the shape of the tank the pump sits at a 27 degree angle from vertical. Would that 27 degree angle be causing the problem? When the new pump gets here, could I test it in a bucket of water before I install it to make sure it works correctly? Will the water damage it? Uncle Gump, you have helped me before and I would appreciate your input again. If I could start this project over I would definitely save myself a lot of effort and expense and start with a fuel injected BII instead of a carbureted one.
First off... I wouldn't test a new pump in a bucket of water.
The fuel pressure regulator on the fuel rail is what maintains fuel pressure at the injectors. You have a return type system... fuel will be supplied to the fuel rail and the regulator will allow any excess fuel to circulate back to the tank... after the pressure needs are met for the engine/injectors. The regulator should maintain fuel pressure at the injectors for days once the engine is shut off. If your pressure drops to zero as soon as the pump shuts off... I would suspect the fuel pressure regulator is bad.
CORedneck
OK uncle Gump I will keep the new pump out of the water. I am checking the pressure at the pump itself with a fuel pressure gauge and I have only had a maximum of 8 psi at the pump itself. As soon as I cut the power at the pump the gasoline drains back into the tank and pressure falls to zero. When I get my third new pump tomorrow, I will hold it vertically in the tank with at least 3" of fuel over the pump and see what happens when I run it. I have 12.5 volts at the pump.
You really need to check your fuel pressure after the pressure regulator. Checking pressure before it is pointless. Checking volume is OK... but it won't build pressure with nothing to pump against.
rgg
QUESTION for "Uncle Gump".
Have almost an identical problem: fires on starting fluid but wont remain running.
Problem first occurred AFTER replacing the TFI (FOR THE SECOND TIME). Ran "OK' for about 1000 miles after second TFI replacement... ran 'rough' with almost no acceleration/gas pedal response (engine 'chugged' almost died).....then died... wont start.
3 QUESTIONS:
1) WHAT CAN CAUSE A TFI TO 'BURN OUT' 2X on an engine with only 100K miles on it ??? (were installed 'correctly' with electrical grease by mechanic)
2) Is it the TPS causing the ECM to 'crap out'/ NOT open the injectors ????
>> Is the TPS a 'common' problem. says "RARE" in post above.
3) Have also been told to check there is a "computer relay sensor" someplace between the battery & the ECM. How to find/test???
other:
Have good Fuel pressure ( ~47 PSI) tested AFTER the FPR to manifold.
Replaced the ECM - old one had LOW (ie. 'dim') 'injector pulse' (Floodie light test). Strong injector pulse with new ECM.
Voltage to computer is 12V steady.
Your thoughts would be greatly appreciated.
Thanks in advance.
Richard
Lets address the TFI module failure first. The number one reason they fail is heat. The location of the TFI on the distributer is not the optimal place for it... it's hard to dissipate heat to an already hot distributer. Many people relocate the TFI over to the fender on a heat sink. There is a how-to in the Tech Library... or... there is a kit available to do it also... below is the link. A bit pricey... but it eliminates searching down the parts and building the harness and modifying parts in the DIY method. The next problem with TFI modules... is some of the aftermarket parts are simply junk these days. Most tend to go for used Motorcraft parts opposed to buying new aftermarket TFI modules.
McCully Racing Motors- We have exactly what your over-heated TFI Module Needs!
Now for the fuel issue... If it will only run on starting fluid... that would indicate a fuel problem. If you have good fuel pressure and you get a good injector pulse (noted by your flashing "noid" light) then i'm at a bit of a loss. Those are the two things you need to make it run. Has it been sitting a long time? Old fuel? Crap in the tank and plugging up the injectors?
I'm not sure about a "computer relay sensor". I know power to the ECM comes through an EEC relay... located in the underhood fuse relay center. I would suggest picking up an EVTM manual. I just bought one for my Bronco II on ebay for less then $20 delivered. If you want to do your own repairs... that manual is just plain priceless.
rgg
Great !
Thanks for advice.
IS THIS THE MANUAL YOUR RECOMMENDING ? (see PIC/Links)
HAS 'STEP BY STEP Diagnostic /repair procedures ? ??? Right ?
15503
LINKs:
PS- was sitting for 8 mos. after engine failed to start. Service Tech (ASE cert) says gas octane rating test is good but gas is 'yellow'. Just before the engine quit I did a fuel fill up ( 1/2 half tank) . BAD gas could cause ALL injectors to clog/fail all at once ???
Do you recommend tank/lines/filter/injector flush ?
IF injectors are 'clogged' HOW do I clean them when engine is not running ? Pull them & diesel/cleaner soak (~ 72 hrs) ???
Great !
Thanks for advice.
LINKs:
That is the EVTM I'm suggesting. It will come in handy.
It's probably a long shot that All the injectors are plugged... but with good fuel pressure and the ECM pulsing the injectors... I'm not sure what else it could be. I would try draining the fuel and using fresh fuel just to see if it will fire.
They sell rebuild kits for the injectors and there are tests to insure they're good. I would first try testing/cleaning/rebuilding the injectors before just replacing them with aftermarket units. Those are a crapshoot these days too.
