ErinBronco2
- Jun 25, 2019
- 24
- 8
- 3
- Age
- 31
- Wisconsin
- 1984
- Ford Bronco 2
- Suspension Style
- 4wd
I've got a 1984 Bronco 2 with the 2.8L V6. Did the Duraspark conversion and it's got a brand new distributor, spark plugs, and plug wires. My dad is a genius with this type of stuff, but I'm trying to be a little more independent. Before I drove this thing home, he adjusted the timing slightly in an attempt to make it a little easier to start. Whatever he did, it didn't make it any easier to start but it also didn't make it any worse.
Currently, when I try to start it "cold" (it's about 60F here), I have to hold the switch on for anywhere from 10-20 seconds before it wants to start. Giving the gas pedal a pump or two before starting seems to make starting take even longer, like it's flooded. This morning for instance, I tried to start it without touching the gas at all. After about 10-15 seconds I sounded like it was just barely thinking about starting. I stopped and let it sit 10-15 seconds, gave the gas pedal one pump and tried again. Same thing, 10-15 seconds of holding the key on before it started.
Is there a simple solution to this or is it normal? My thought is that the carburetor needs to be refreshed, cleaned with new gaskets and seals. Am I on the right track? Also, am I going to ruin my starter by holding the ignition on for that long?
I've got a very basic understanding of Bronco 2's at this point. I'm slowly learning but I'm definitely not an expert, so feel free to tell me like it is. Thanks!
