1985 B2 A/C compressor upper line manifold
Looking to replace the air conditioning that PO had removed from my 85 B2. I have a new compressor but in need of the manifolds that attach to the top of it which the ac lines attach to. Let me know if you have and message me on what you need for them. Thanks.
Bronco 2 man
Boiling springs lakes nc
Bronco 2
Hey Gordy if the ranger is the same I have one I think off an 84 ranger! I’ll send you some pics here in a few of it.
Bronco 2 man
Bronco 2
This what you need Gordy? Not sure if it’s the same between the Bronco ii and Ranger thinking it is and should be! Just let me know.
That looks like the parts. Also, mine is missing the wire that attaches to the compressor. Does yours have it still? I have no idea where that wire runs from, out of a wiring harness I assume? Shoot me an e mail at gklug305@msn.com
Also, are you parting out that B2? There's a few other items I might be interested in. Thanks.
Actually just heard back from someone who had messaged me earlier. Will close out the post if he comes thru with the parts. Thanks.
It worked out as I was able to pick up the two compressor manifolds I needed as well as
the complete wire needed to the compressor from the right side fender wall
Desert Bronco
BRONCO
I know this is a old post but I need One of these badly to complete my 85 Bronco AC any help would be appreciated.
Is it the 2 manifolds that attach to the compressor that you need? There is a salvage yard near me that I saw had them . It's been a few months since I was there but unlikely that they went anywhere.
I can check next week to see what he would want for them.
When I got mine from a boneyard in N Carolina they were $20 each (with the bolts). Not sure what this guy down here will want for them. Do you need any of the lines if they look good?
Desert Bronco
BRONCO
No, got new lines. Just the adapters and bolts.
Desert Bronco
BRONCO
Gordy, I have a 85 Full Size Bronco not B2 not sure if they are the same
Peter Griffin
I just went through a similar 💩 show myself when I threw away my old A/C compressor when my new one came in without taking the manifolds off first. Total rookie mistake that sent me scrambling and ended up costing me $100 for a set of new ones here:
Desert Bronco
BRONCO
Thanks Guys I ended up getting the new ones . FYI They fit Ford and John Deere . Got mine for a John Deere $70
