1994 Explorer Fuel Pump Replacement
tenacious_e
I just got My Self a 1994 explorer For an incredibly Cheap price ($400), Mainly due to a lower Intake manifold leak. But I have also found that the Fuel pump is starting to go out as well, Some times I have to Turn the key several times to get the Pump to unlock What i wanna know is Has anyone tried Cutting a hole Thru the rear Floor of the explorer To make an access panel to get to The pump? As I said it is a a Cheap truck that I will use for hauling and i dont mind hacking at it a little to make Servicing it easier.
BTW I am a former member Of TRS and it has been so lonfg since I have Been Here That my Old account is either Inactive or i just cant remember it.
Ed Cook
Storm Lake, Iowa
martin
St Bruno, Quebec
1991
It does not take long to drop the tank, on the two door any way. I don't think hacking the floor is worth the trouble considering the possible gains, or not.
fastpakr
Roanoke, VA
2.3 Lima
Are you sure that it's the fuel pump and not a wiring fault? I'd definitely grab a meter and test to be sure before replacing.
Little X
SW VA
Check EF, BURNS has a how-to on cutting a hole and changing the pump.
tenacious_e
I Did as well of an electrical Check as i Could and I Could not Find any Shorts In the Harness And The harness is Getting Power from the relay. When It Does run it Is alot Louder than it Should be
Cutting and patching The Hole will not be a problem, i have Access to a Good metal Shop and can make a New panel Easily
tenacious_e
Where's my Dunce cap at? ;brownbag;
I checked everything electrical from the Relay to the pump, Except for one thing....
Ground wires at The Battery, A previous owner Put one of those el-cheapo Battery terminal clamps On and Cut one of The Ground wires too short, so it was barely held In place by 2 strands. For The time being i Split bolt On an extention and the pump Runs and sounds better Than before.
At least i did not put in all the work and expense into replacing the pump Before finding This
