'84 Bronco II
- Jan 12, 2009
- 32
Also, I will try and take a look to see what size jets are currently in my carburetor.
Do not attempt to time it by earball use a timing light and set it at 10 degrees btdc with the advance disconnected and plugged. Then adjust the idle air needles for the highest rpms or vacuum pressure. You should have 10 degrees advance when you hook manifold vacuum up to the dizzy. Use the pointer not the round thing to set the timing. with a flashlight and a socket get under the front of the engine and rotated the crank clockwise until you see the timing marks the wide groove marked TC is TDC the next numbers are twelve. with a yellow crayon mark it one line back toward TC that is !0 degrees. Allways adjust the idle air needles after you change the timing. Before you pull the float to check the jets check your wet float setting you want 3/4 inch center of the fuel in the bowl to the top of the float bowl. Pull the float to bend the arm and then soak up some fuel with a rag. Disconnect the coil wire and crank on it unitl the fuel stops and check your level again. Do not try to adjust the float in the carb you will damage the needle and seat. If your careful you can run the motor with the top off the carb to check the wet float. If you do these thing in order I can almost guarantee you will bring that engine to life.
1-Put smaller jets in #43 to begin with
2-confirm 3/4 inch wet float setting
3-turn the idle air needles out 3 1/2 turns pre adjust
4-Start motor and bring up to temp then adjust idle to around 700 rpms
5-adjust base timing at 10 degrees (DBTDC)
6-Set idle air screws for the highest lean vacuum pressure (where vacuum drops as soon as you turn them in)
7-Connect the vacuum advance to ported vacuum on the carb.
8-Take it for a beat
I do this for every tuneup except check wet float with great results the base timing has not moved in four years I run autolite single platinum plugs and the stock TFI coil it jumps a gap around 7/8 inch with a wicked snap. I was messing with the vacuum for my tranny and knocked a plug wire up and my whole arm went numb in a split second.
