302 swap
jmlaut21
pittsburgh, pa
anybody have experience putting a 302 efi with the a4od into an 1985 bronco ii. i have the whole donor truck with all pumps, wiring, and computers. i am thinking the transmission or ass end of the engine may not fit. Any suggestions?
kemicalburns
Oregon City,OR
a4od? do you mean AOD or E4OD. there is a difference as the e4od is electronic overdrive and needing a few sensors to work properly. the AOD would be the easier to install.
Gotta_gofast
Wisconsin
6.0L Powerstroke
The E4OD is considerably larger than the AOD and requires the computer to shift it. The AOD (with a 157 tooth flywheel housing) is the smallest and will fit quite well, this is what I run. Some notes about the AOD
-Throttle Valve (TV) linkage must be set accordingly or you could wind up killing it within a mile
-Usually the first thing to go in an AOD is either the OD band or the smaller input shaft. The input shaft will sheer when the transmission is shifted from 2nd to 3rd or 3rd to OD because this is when the engine's load changes from the outer shaft (from torque converter) to the inner shaft (direct torque from engine). The '88 and older tailhousings have extremely poor lubrication and should be changed to the newer style if running 3.55:1 gears or higher. Also, the AOD has a shift pattern of 1-D-OD (which sucks) and the E4OD has 1-2-D/OD I believe. If you do infact have an AOD I highly recommend a LENTECH VALVEBODY. I am extremely pleased with mine and it eliminates most all of the AOD's flaws including changing the crappy 1-D-OD shift pattern to a more user friendly 1-2-D/OD. It also allows 3rd gear to be completely driven off of the outer shaft so you don't have to worry about harsh shifts sheering the inner shaft.
