BabyBronco89
- Dec 9, 2011
- 200
- 2
- GR Michigan
- 1989
- 95' 4.0 OHV
So I think I have the basics covered
I've done this swap once before in a 89 b2 so it was a lil easier then this one is gonna be,
I have a 86 b2 made 10/85 2.9l efi
The donor is a 90 ranger 4.0l I'm not sure if it is auto or man trans I'm guessing auto, I know the harnesses are the same I had a auto harness out of a 91 auto explorer for my last swap..
I'm using the stock fm trans from the 85 along with the 2.9l flywheel and clutch and starter, until I can upgrade trans and clutch to 4.0
Now I plan on taking the entire harness, out of the ranger the engine harness dash harness all the way to the taillights, intake, fuse box radiator the works
I also need to take the fuel pump and all fuel lines out of the ranger correct??? Or will the stock 2.9l fuel pump system be sufficient??
I have some weird secondary fuel pump under my drivers seat frame rail, where the fuel filter was in my 89 so I'm a lil confused there
I know it's easier to take out the whole dash so I just might do that too
It's also this 2nd gen ranger has an immaculate front clip... I need two fenders due to rust and could use a new hood, so I might just be getting a the 2nd gen bronco front end swap as well
Everything is 50% off for their Labor Day sale!!!
157$ for a complete engine with a 50$ core
I'm hooping I can get everything I need for under 300$
Happy Labor Day guys, keep the ideas coming.
