AledoGYoung
- Apr 29, 2013
- 24
- 1988
My first problem with my 88 bronco ii push button 4wd was the rubber bushing in the shift motor. That fixed it for a while then my shift control module went bad so I replaced it with one that I got from a junkyard. After that my 4wd worked fine for probably 6 months and all the sudden it doesn't work again. The module self tested good, then I took the shift motor off and the rubber bushing I replaced was kind of mashed so I replaced it. I hooked it all back up to see if it works and the motor goes into 4 high but the module clicks several times and the motor moves in between two positions in the 4 high area then finally goes back to 2 wheel. It is almost like it is not going into the perfect position or can't read what position it is in so after a while it goes back to 2 wheel. Please if anybody has any information to help me out let me know. I am trying everything before the last option I have of buying a new shift motor. Thanks
