5.0l '89 Bronco II
alpinestar
Vancouver, Wa
5.0l
I just bought an '88 Bronco II with a 5.0 from an '88 thunderbird. the wiring... well its the scariest thing ive ever seen to be honost. So the plan is to swap the 5.0 from the '88 bronco into my '89 that most of you have seen already. The 5.0 has a c6 and np205 behind it, the c6 shifts great has the B&M shifter, and the np205 has a twin stick kit. Also the engine is rebuilt.
So the only questions i have are:
Can i cut the wiring after marking everything so i know whats what, and just splice it back into the wiring in my '89? so basically cut the 5.0's harness into a few pieces and then splice it into the '89 and do the same for all the plugs for the computer and all that.
or... would i be better off getting a whole thunderbird wiring harness and trying to splice it into the wiring into the cab? that to me seems harder i just dont want a big ugly mess like the '88 that i just got has.
alaskan155
Cheyenne
honda and ford
2.4l/5.0
Should beable to just cut and spice the new.harness into the 89 just need a good wiring diagram. To help you out save the 2.9s oil and coolant and low oil sensor harness that will be plug and play for the 5.0, the tac has a v8 pin on the back ground that out and run the signal pin/wire to to the - side of the coil the alternator is plug and play into the 89 that just leave the cpu and the rest of the engine harness which with a diagram from autozone.com and a good voltmeter wiring shouldn't be to bad
Once you get it going though can u tell me how that dana 30 holds up?
Should see the mess I got from all the leftover f.I. Wiring that's my next step to clean up when I intall the 84-88 radiator support on my 89(gonna redo how I have the explorer radiator tucked and fix all the wiring while its apart
alpinestar
Vancouver, Wa
5.0l
k cool that helps alot man.
and the 5.0 is in a bronco II on stock running gear with a 6" lift and 35's and it hasnt broken anything yet. and im welded in the rear... but the dana 30 will just break axles if anything, no biggie for the amount of money you save versus a 44..
