Ryannn
I just bought a 78-79 Dana 44 with disks and the casted wedges are you able to use that to sas a bronco 2? I'm not sure if it has been shortened.. will post pics later
You could always build it a full-bump, then lift it to ride height to figure track bar and tie rod length.That is the only part of the sas im worried about is the arms and where to mount them...
My point exactly! Would I need the original arms to build off of?James Duff, Bronco Graveyard, Tom's Bronco Parts, there are plenty companies producing custom arms. The problem is the price, who in their right mind spends that much money, when you can build them yourself from $0-$250...
Sent from my HTCONE using Tapatalk 2
Build it with it stuffed all the way up?You could always build it a full-bump, then lift it to ride height to figure track bar and tie rod length.
Yes, with the front caps.My point exactly! Would I need the original arms to build off of?
Really? Sorry...You have been whoring the $#!+ out of your build lately...
