I`m sorry I thought the computer was working the knock sensor is out of play. Your running on base timing at 10 degrees full time it is a wonder you get any power at all.
No problem, I'm not really sure if the computer did work in it correctly before I pulled the relay out due to it going into some sort of limp mode which would give me about 40MPH top speed and was constantly cutting out, like I said after I took out that relay by the computer it now runs awesome except for the stupid knocking noise that decided to show up, which has me puzzled because when I heard it intermittently before it was because the carburetor wasn't adjusted right, I'm not sure if it keeps adjusting itself by vibration or what but I can't keep it at a steady idle to save my life, I get it set once it warms up then it won't stay running when cold, then after a while it is idling high again. The reason I'm confused now is the problem is constant anytime I accelerate from a stop up to cruising speed, before it never had the knock noise this bad.
The Haynes manual says:
Pinging or Knocking Engine Sounds During Acceleration or Uphill:
1. Incorrect grade of fuel.
2. Fault in fuel or electrical systems
3. Ignition Timing Incorrect (ruled that out this afternoon)
4. Carburetor out of adjustment (Kind of leaning back on this now as it seems to keep adjusting itself).
5. Improper spark plugs
6. Spark plug wires damaged
7. Worn or damaged distributor components
8. Faulty emissions system (umm yeah none of that stuff is even present thanks to previous owner).
9. Vacuum leak (tons of those but didn't cause this knock issue before). The only vacuum leak it has now is the brake booster connection that goes into the booster itself is leaking but its been doing that since I got it, and hasn't had the knocking noise the whole time just intermittently up until this past Sunday then its become a constant knock under load.
I can raise the throttle level up just sitting in the driveway and I get no knocking so that tells me at least I don't have a rod about to exit the engine LOL. Although the noise isn't that loud. I've had like this knocking noise before, but after I had the truck in and had some work done and the carburetor cleaned and adjusted it stopped, now the noise is back again, so I'm wondering if the carburetor could just need adjusted once again.
If its the carburetor adjustment, the initial settings for the front screws are 3-1/2 turns out from slightly seated correct? Haynes manual doesn't say a thing about adjusting the carburetor just how to install and remove it, this manual is worthless IMO.
