derrik
- Dec 30, 2011
- 1990 & 2002
- ford's
the bronco has been parked due to tranny problems,it is in southern cali while im in northern cali heading out for deployment,so im trying to do all my homework so when i go back home from deployment i can get this tranny situated in time for me to drive it back to norcal.
not much info on the tranny,im told its a toyot 4speed.i literally spent my whole 8 hour shift looking into this tranny and swaps.
im considering an m50d,but just to clarify,i am going to need everything including flywheel clutch and slave,and to be able to retain factory speedometer i must get a m50d out of a vehicle 94' and older correct?also curious it has been said by someone else that if i snag an A4LD front driveshaft it will bolt up along with this setup which just leaves my to get the original drive shaft shortened?
next is the toyot tranny,ive seen rebuild kits for around 150 but bronco graveyard no longer list's the kit.if they can still be had, how hard is it to rebuild this tranny.it will be my first attempt at a manual trans rebuild,info seems very scarce,thanks for reading.
