85 bronco stalls/no start when wheel is turned
1985FordB2
I have an 85 bronco that cranks and doesn’t start when I have the wheel turned all the way (parking on an incline).
Also when I’m making sharp turns or I turn the car stalls and dies.
It’s never done this before cars been reliable. Im thinking it’s something with ignition switch? Can this cause no spark also?
tw205
Bronson michigan
Put a test light on the + side of coil and turn key to on. Should get a light. Now turn the wheel lock to lock and see if the light goes out. A bad connection to the ignition switch can cause your issue. I always try to duplicate the failure and isolate it to a component before changing anything or you just chase failures and bad parts. The connector to ignition switch on the steering column are known for coming loose. 1 of mine does it (85 BII). I had to put a zip tie on it to make it stay firmly connected.
