86 b2
koomz
abbotsford
Bronco2
2.9L v-6
sorry i put this in the wrong thread..but heres my bronco 2
6'' lift on 33 bfg muds..stock motor/trans/t-case.(2.9L)
detroit locked rear..8.8 and open front d35 explorer diffs.
6000lbs warn winch..fender flares off a full size bronco cut to fit..
roll bars..tool box..over all happy with it.. total cost of build including truck came to $1960 dollars..but i have all the tools and a shop.
97fordrunner
New Richmond, WI
This is the right thread for a BII, What are you running for gears? Does that Warn pull good when you get in the thick stuff?
BlackBII
Cheaf of Grammor Poleace
Orem UT
I like the chopped top!
You oughtta get some pics up that aren't puny so I can see how you chopped it :icon_thumby:
koomz
abbotsford
Bronco2
2.9L v-6
im running 373 right now but will swap to 488 when i can on 35's..the winch works really well...some say 6000 is just enuff for the b2's..and 8000 is overkill...im new to winches but with a snatchblock and my truck tied to a tree i pulled my buddies ford f250 on 44'z out of a sticky hole...so im happy its plenty for this truck
hey black b2 thanks ..i think u gave me info on the explorer 4L starter and clutch swap was it you that gave me a wiring diagram..if so thanks....i will get bigger pics up for ya..
