86 bronco 2 will not go into any gear
taj
Ford bronco ll
I pulled the transmission to replace the main seal and the filter and when I was putting it back together I wound up with two two pin connectors that I don't know where they go and the transmission will not shift into any gear. Any help would be greatly appreciated.
taj
Ford bronco ll
Also has an aod trans.....
Reverse lights, safety switch and converter lockup should be down there. It’s been a while since I’ve been under mine. Check drivers side above and next to the shift lever.
taj
Ford bronco ll
The plug is in the harness about six inches back from that multi pin plug in the trans and it's on about a six inch pigtail. As far as not getting any gear I think I didn't pull the inner shift rod all the way out by hand before I put the nut in the kickdown linkage arm
