turmanator
- Mar 4, 2013
- 18
- 1988
Hey, my 88 bronco II XLT just developed its latest problem. I replaced the tfi about 2 years ago (sat for a year) cap, wires, starter solenoid, fuel pressure regulator (within the past year and 1/2), pcv, ECT sensor, fuel pump relay, tps, cleaned the throttle body, new fuel filters, cleaned the injectors within the past month or so.
i pass on all codes KOEO but am getting a code 21 KOER but i just replaced the ECT, i am at a loss. I took a 450 mile trip with no problem until the last hill dropped me from 75 to 55 with the rpm going from 2200 to 1500 acting like it was starving for gas but it kept going, pulled over (had to piss) and it died on me than wouldn't start for another 15 minutes, would just turn over, and ever since everytime i drive 20 minutes it does the same thing, i can slowly put the pedal down but if i really try taking off it acts like it starves, only when its warm though. The HP fuel pump seems to be getting louder as well.
It idled fine for about an hour with no hesitation with the hood open, down it will die in about 15 min. my gas tank is rusty but the filter didn't seem to be clogged when i pulled it. Any thoughts would be appreciated. Also it has always ran rich and i do not blow black smoke. Pulled the MAP and it died so seems like its working, i checked the voltage of the TPS and it sat at 5v the whole time, idle and WOT which confused me. Thoughts?
