88' Fuel Filter
MLB
88' Bronco II with 2.9 is there a filter in the canister on the frame rail ?
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
Farmington Il.
Look under the drivers door on the frame. Should have 4 lines coming into it. When you change it out becareful that the "O" ring seats correctly.
Steeda04SVT
U.S. Military - Active
Clovis, NM/Cannon AFB, NM
I just bought a Wix fuel filter too to change out in my 90 B2. How hard is it to change out? Where is the fuel cut off switch as well so I don't get a face full of fuel?
MLB
I have heard conflicting stories, some say the 85' and 86' were the only years to have a filter in the canister and 87' and up it is more or less a fuel bowl in case the low pressure pump sucks air. Does anyone know for sure if the 88' has a filter or not, I don't want to get a face full of gas if I don't need to. Thanks.
ksum25
Apple Valley, CA
2.9 fuel injected sucide machine
My 88 Bronco II has nothing inside. It was a pain to put back with the o-ring.
