89 B2 FM145 Trans fill plug
Murhpi
Portland
I pulled the trans to replace the clutch and while prepping noticed that the fill plug was all sorts of mangled. It appears someone went at it with a pair of vise grips. I drained it and got the trans out, but after looking at it in daylight, realized that there is just no way that this bolt is coming out. So my question to you fine B2 lovers, how do I refill the transmission with fluid? A mechanic told me to just fill it in the hole that the shifter goes into at the top. If this is accurate I will replace the trans and refill by volume, if not, what other suggestions do you all have?
James H
Spokane wa
2.9 V6
Hold my beer and watch this!
Following this. My fill plug is f'ed up too.... No one lists a replacement, and it's a DD so I can just get it matched. But if the trans is out, see if a local parts or hardware store can match up a replacement.
Sent from my Moto Z (2) using Tapatalk
