1BadRS
1984 Bronco II with a duraspark conversion. I just installed this 2.8L motor and also swaped out the C5 for the M5OD. After wiring in the new starter as asdm08 recommended, I was able to get the truck to turn over. Now for some reason when I turn the key to start, I'm only getting a clicking sound at this box mounted under the dash above the kick panel on the driver side. If I left the key in the run position and jumped the fender mounted solinoid I was able to get the truck to turn over. Where should I start looking to solve this issue?
The other issue I am having is when I was jumping the fender mounted solinoid, the truck made no effort to even try and start up. It just cranks and cranks. I poured a little gas in the carb so I'm pretty sure i'm good with air and fuel. How do I check to make sure I'm getting spark?
Thanks
Thanks
