A4LD questions
nossbud
i have a 1987 Bronco II with a A4LD transmission i believe. how do you get the shift arm off? the first one sides off nice but the second one wont. i think the first one is for the push button on the shifter itself. also is there only 6 bolts in the bellhousing to the block?
2manyfords
Brandon Manitoba Canada
Try using a heat gun or a hair dryer to heat the nylon bushing that it clips into.
There are 6 bellhousing bolts and 4 torque converter bolts.
